1997 Chevy Silverado Hard to Stop
1997 CHEVROLET SILVERADO
C3'S ECHO
Brakes problem
1997 Chevy Silverado V8 Two Wheel Drive Automatic
I have a Chevy truck 1500 that in order to stop you have to press the brakes really hard. At first I thought it was because the rear brakes need to be adjusted. So I adjusted them and that didn't fix the problem. I recently replaced both rear wheel cylinders beacuse one started leaking fluid. I have no idea were to look or what I can do to fix this problem.
Feb 12, 2009 at 12:59 AM
  • 110,244 POSTS
Are you getting proper vacuum assist from the brake booster? Sort of a hard peddle?
Feb 13, 2009 at 8:51 AM
C3'S ECHO
I replaced the brake booster vaccum line and that made now change. But after changing that line i noticed when depressing the brakes the mastercylinder makes like a swooshing sound
Feb 16, 2009 at 9:53 PM
  • 110,244 POSTS
Is it working correctly now?
Feb 17, 2009 at 12:01 AM
