1997 Chevy Silverado flooding
KEPPOCHGUY
Engine Performance problem
1997 Chevy Silverado V8 Four Wheel Drive Automatic 290 km miles
my truck will not start if left sitting for 2 or more days, it will turn over but will almost start, but wont, if left for a few hours it will start but idle rough for about a minute. it starts fine if started every day, also you can smell gas when it does not start
Jan 28, 2010 at 3:31 AM
MERLIN2021
  • 17,250 POSTS
Start with the basics, and work your way up, Last tune up was? Wires plugs ALL filters? If all that is ok, check for a stuck EGR, then test fuel pump pressure, If it won't restart, determine what's missing, the engine needs three things to run, Spark at all plugs, gas to all cylinders, and compression in all cylinders, tho an engine may run lacking one in one cylinder, it won't run very well!
http://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
http://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
and this one!
http://www.2carpros.com/first_things/car_cranks_but_wont_start.htm
http://www.2carpros.com/dia/how_to_check_compression.htm
http://www.2carpros.com/dia/index.htm
Jan 28, 2010 at 4:36 AM
