My battery seems to be failing
177,000 MILES • V8 • 2WD • AUTOMATIC
DASEVILLE
I have a Sivlerado with an after-market, competition level stereo system. I have a high-output amplifier, powering 3 Amps, 3 capacitors, 4 subwoofers, and 8 midrange and tweeters. When my car is powered on, the capacitors read 13.6 - 13.9 Amps, and my voltage gauge reads around 14.
My battery seems to be failing. I had left my lights on all day, which killed my battery. I had it jumped and when I got home I put it on a charger, and did not have a problem again. A few weeks after that, my wife left the dome lights on overnight which again killed my battery. Again I charged it overnight and it was fine for another few weeks.
Now, for no apparent reason, my car wont even hold a charge for more than a few hours. It seems to be deteriorating more rapidly. If I charge it overnight, it will fire up OK for a while, but when I went to work, it did not even last a 7 hour day.
Sorry for the long description but I wanted to provide as much info as possible before asking my questions.
My question is: has the multiple charges and discharges caused my battery to go beyond the ability to hold a charge? Or does that seem circumstantial and it could be something else.
Right now I have a cheaper Carquest battery, but am replacing it with a higher end Optima battery. I just don't want to get my hopes up if this is not the issue.
Any advice/help would really set my mind at ease.
Mar 17, 2010 at 6:51 AM
OPTIMAJIM
Hi daseville, Docfixit is correct, in that no battery likes to be deeply-discharged. Deep-cycle batteries are more resilient to this type of service than SLI (starting/lighting/ignition) batteries.
The most important key to long battery life is maintaining voltage of at least 12.4 volts at all times. If your vehicle does need to be jump-started, fully-charging the battery with a battery charger is also a good practice.
I assume the extensive list of audio components you have installed also includes the "Big 3" wiring upgrade? Grounds should always be double-checked, as there is no such thing as grounds that are "too good" and one-wire alternators are especially sensitive to good, quality grounds.
If your system is competition level, it might be appropriate to consider an upgraded alternator and an isolated, dual-battery setup. This would protect your SLI battery and allow it to start your vehicle, even if you have deeply-discharged your auxillary battery. Cold cranking amps are an important consideration in cold climates, but reserve capacity is a more important consideration in car audio applications.
If you do decide to purchase an OPTIMA, we strongly recommend a YellowTop for all applications with significant electrical accessories, such as yours. If you have any other battery-related questions, I'll do my best to answer them.
Jim McIlvaine
eCare Manager, OPTIMA Batteries, Inc.
www.facebook.com/optimabatteries
May 13, 2021 at 11:55 AM
