1997 Chevy Silverado cuts out going up hills mostly
156,000 MILES • V8 • 2WD • AUTOMATIC
PLEMMONS
I have changed plus wires, air filter,oil, and recently changed plugs couple weeks ago, also I have replaced fuel filter couple months ago and replaced fuel filter also with pump and when i go up hills (mostly) it cuts out sometimes when i have it on cruise control it does it also. Every once in a while it will foul the 2 front drivers side plugs out, so can that be the problem or do i need professional help tp look at the problem and does it need immediate attention.
May 4, 2008 at 8:31 AM
MASTERTECHTIM
  • 4,750 POSTS
sounds like possible fuel injector problem. a fuel injector balance test will be the next step and will have to be done at a shop
May 4, 2008 at 8:37 AM
