1997 Chevy Silverado check engine
153,550 MILES • V8 • 2WD • AUTOMATIC
MIGEARE
my truck has the check ingine on i took it to auto zone and they said that my truck is misfiring so i changed the spark plug, wires, cap and router and the coil and it still is on so they said that i might have a loss conection on my crank sensor or my cam sensore what can i do
Jan 25, 2010 at 3:25 PM
  • 75,988 POSTS
Check and test the following below:
An engine misfiring can be caused by worn or fouled spark plugs, a weak spark (weak coil, bad spark plug wire), loss of compression, vacuum leaks, anything that causes an unusually lean fuel mixture (lean misfire), an EGR valve that is stuck open, dirty fuel injectors, low fuel pressure, or even bad fuel.
Jan 25, 2010 at 3:31 PM
