1997 Chevy Silverado blinkers
260,000 MILES • V8 • 4WD • AUTOMATIC
JUSTINM10
  • 5 POSTS
soon as i turn the key on the fuse will blow. but if its in nuetral when i turn the key on it will not blow. do you have any suggestions what it might be
Sep 30, 2010 at 2:34 AM
WRENCHTECH
  • 20,760 POSTS
Not without knowing what fuse your talking about.
Sep 30, 2010 at 2:50 AM
JUSTINM10
  • 5 POSTS
it is the fuse for the blinkers
Sep 30, 2010 at 3:52 AM
WRENCHTECH
  • 20,760 POSTS
That fuse also powers the back up lights which are controlled by the range selector switch on the left side of the transmission. That switch is likely shorted out internally.
Sep 30, 2010 at 4:05 AM
JUSTINM10
  • 5 POSTS
that would cause the blinker fuse to blow . do i need to just get a new one or is there a way to fix it?
Sep 30, 2010 at 4:21 AM
WRENCHTECH
  • 20,760 POSTS
No, it would need to be replaced.
Sep 30, 2010 at 4:23 AM
JUSTINM10
  • 5 POSTS
is it the same thing as a neutral safety switch
Sep 30, 2010 at 4:35 AM
WRENCHTECH
  • 20,760 POSTS
Yes, but they don't call it that any more. It's usually called a range sensor or range switch.
Sep 30, 2010 at 4:37 AM
