1997 Chevy Silverado adjusting lifters
82,000 MILES • 6 CYL • 2WD • AUTOMATIC
ERG1956
how do you adjust the lifters and how tight do you tighten the nut of the rocker arms
Aug 8, 2010 at 10:49 AM
HMAC300
  • 48,601 POSTS
they are hydraulic and need no adjustment unless you have replaced something. But if you need to adjust htem, then the procedure is bring #1 to TDC and take lash out of lifter and then 1 ful turn down. Continue the rest of the way throughout the engine with each cyllinder.
Aug 9, 2010 at 2:17 AM
