1997 Chevy Silverado AC question
98,000 MILES • V8 • 4WD • AUTOMATIC
BRUCKER
My a/c is not working. I've bought a re-charge kit and after reading the directions and hooking it up. It shows I may have some mechanical problems. My compressor clutch is engaged when the a/c is set at high and the engine is at idle. It shows the pressure as off the charts high when hooking up the re-charge kit as well. When the compressor clutch engages it makes a loud continuous rattling sound. What's the problem??
Aug 20, 2010 at 11:07 AM
  • 75,988 POSTS
Sounds like the compressor is fixing to go
Aug 20, 2010 at 11:09 AM
BRUCKER
[quote:4c2abf60fc="rasmataz"]Sounds like the compressor is fixing to go[/quote:4c2abf60fc]
Is there anything I can do at home to get it to work?
or
Should I get it into the shop?
Aug 20, 2010 at 11:12 AM
  • 75,988 POSTS
I suggest you just bring it in might not be too simple let the pros handle it-
Aug 20, 2010 at 11:19 AM
BRUCKER
[quote:84125dfe3d="rasmataz"]I suggest you just bring it in might not be too simple let the pros handle it-[/quote:84125dfe3d]
I was afraid you were going to say that. Thank you for the help.
Aug 20, 2010 at 11:24 AM
