1997 Chevy Silverado
135,000 MILES • V8 • 4WD • AUTOMATIC
BAM20BAM21
my 1997 chevy truck wont start it cranks and turns over then spins out. changed the coil
Jan 19, 2008 at 11:28 AM
BLACKOP555
  • 10,386 POSTS
well try spraying some starting fluid directly in the throttle body while cranking it, if it fires up you are not getting fuel and you shoudl proceed to check for 12v at the fuel pump connector and fuel pressure at the fuel rail post back what you find.
Sep 2, 2020 at 10:48 AM
