ive charged my ac and its leaking out the end where you charge it at.
Jun 8, 2010 at 2:34 PM
BLACKOP555
✓Experienced Mechanic
if its coming from the charge port you are going to have to evacuate the entiresystem and use a service port repair kit and put in a new stem if possible. if not you need a new line. be sure to add new oil when recharging it.
and also a little bit of oil is normal after charging it but should not be hissing out
Jun 8, 2010 at 4:32 PM
