1997 Chevy Silverado
ANNIE111
Electrical problem
1997 Chevy Silverado 6 cyl Two Wheel Drive Automatic
It keeps blowing fuses and will not start. I think its the auxillary fuses. I kept replacing them and they would continue to blow. I then replaced them with a 60 amp and it worked for a while and now its blown again. What can I do?
Aug 5, 2010 at 10:05 AM
  • 110,251 POSTS
Never replace a fuse with one of higher amperage. If it doesn't blow, you will end up with an electrical fire.
Now, what fuse is giving you trouble? Also, when you did have the higher amperage fuse in, did the truck run?
Aug 5, 2010 at 3:46 PM
