1997 Chevy Silverado
239,098 MILES • V8 • 2WD • AUTOMATIC
QMECHANIC
I am having idealing problem.I chang the IAC,MAF,MAP and all 4 oxygen sensor befor/after catilitic convertor.All the electric connector's and hose's seem to be in working order.The fuil mixture seem to be too rich.I check for vaccume leak's with soapy worter.
Aug 8, 2009 at 9:05 AM
BUDDYCRAIGG
  • 2,262 POSTS
if you're running rich then we have two roads to follow.
too much fuel,
Leaking injectors
Pressure regulator is not working correctly.
not enough fire
Weak spark
Aug 8, 2009 at 10:23 AM
