1997 Chevy Silverado
77,000 MILES • V8 • 2WD • AUTOMATIC
BCMINIMART
truck seemed fine but driving home one day i felt the trans slipping from startoff,when i got home ,next morning when i get ready to go i dont have reverse,slipping in low gear too, do i need a trans and if so will one out of a 99 with 5.3l fit?
Jan 11, 2010 at 11:32 AM
OBXAUTOMEDIC
  • 3,718 POSTS
Have you check the Tranny Fluid for Color, Order and Level?
Also is engine light on? If so need to get codes read. Your local parts store will do it and usually for free. Post codes here.
Jan 11, 2010 at 11:46 AM
BCMINIMART
fluid looks fine red in color,full,havent read codes,found a 2000 chevy with 5.3l is this same tranny
Jan 11, 2010 at 12:39 PM
OBXAUTOMEDIC
  • 3,718 POSTS
Is you 97 a 5.3.
Is the 2000 2wd or 4wd. If 4wd it won't work.
Not sure if would if otherwise would need nore info on both vehicles to determine....
Need...
Year - Month and Year
Make -
Model -
Sub-Model -
Engine Size (Liters) -
Vin # -
On both vehicles. The 2000 may have a more electronic tranny than the 97.
Jan 11, 2010 at 3:16 PM
