1997 Chevy Silverado
200,000 MILES • V8 • 4WD • AUTOMATIC
DCAMP
At times my truck boggs down when you try to accelerate. If you don't let off the gas it will die. It will idle. When this happens I can shut the truck off and start back up with no problems. It happens about 3 or 4 times a month usually at intersections or going up hills.
May 15, 2009 at 9:02 PM
DR LOOT
  • 2,311 POSTS
That could be multiple problems, like the throttle positioning sensor, or a weak fuel pump, or a plug up fuel filter, do you have a check engine light on?
May 16, 2009 at 5:35 AM
