When driving at cruising speed around 55 + MPH the speedometer jumps up and down. This causes the truck to shift up and down on occasion. It also throws my truck out of cruise control. It has been acting for a while now that when cruising it will be fine then jump up about 3 hundred rpm's and then after a while it might go back down. I dont know if the two are related. Im not sure if it is jumping in and out of the passing gear or not for the later problem. For the first problem I am thinking it is the sensor on my tranny that controls the speed and comunicates with the ecu. If that is what you think it is as well do you know of any ways to test this? I also just installed a stereo in my truxk and had to remove the guage cluster im not sure if these are related or just coinsidence. It has been jumping in and out of the passing gear I think thats what it is doing anyways for several months. I dont think it is related but I want you to have the whole story. So what do you guys think???
Nov 12, 2008 at 8:04 PM
