1996 Chevy Silverado NO SPARK TO CYLINDERS
150,000 MILES • V8 • 4WD • AUTOMATIC
MILLERTL5
my truck turns over but does not fire. When I changed the plugs, I noticed the plugs were wet and smelled like gas. I think I'm getting no spark to the cylinders. I had the control module tested and it is fine. I'm at a loss where to go from here. Any suggestions?
Mar 5, 2009 at 8:49 AM
  • 75,988 POSTS
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Mar 5, 2009 at 9:00 AM
