1996 Chevy Silverado headlights
200,750 MILES • V8 • 4WD • AUTOMATIC
BOATGUY13
I have a 1996 chevy silverado 1500. The headlights stopped working 2 years ago. I always drove with the parking lights on and the daytime running lights since. Now the daytime running lights stopped working. The high beams work but I get some hard looks using them. Can someone point me in the right direction. I have several friends with similar year chevys that have the same problem.
Nov 6, 2009 at 4:07 AM
JDL
  • 16,098 POSTS
welcome to the forum. There is probably a multiwire connector under the dash, close to steering column, that is for circuits going to and from the steering column. Check purple wire for voltage. the high beam circuit is straight off the dimmer switch. The low beam circuit goes through the dimmer to the drl relay, When the relay isn't energized, there is continuity on the low beam circuit to headlamp. The purple wire I mentioned carries voltage for low beam to drl relay. If that wire isn't hot, suspect dimmer switch. If the circuit is hot and no low beam, we''ll have to check drl relay and wiring circuit. The info I looked at was for sealed beam, not quad. All repair info says when doing testing around steering column to disarm air-bag for safety.
Nov 6, 2009 at 4:50 AM
