1996 Chevy Silverado fuel problems
146,000 MILES • V8 • 2WD • AUTOMATIC
MARYG363
my truck dont start only if i use started fluid ther is gas going to the ijectors but not to spark plugs i change the electric module and the coil, check all the fuses but some how the injectors are not going on i check the spark plugs i dont know what else to check
Mar 14, 2010 at 1:06 PM
  • 75,988 POSTS
Check the fuel pressure if its within specs if okay hook up a noid lite on the injector harness it should be flashing or listen to the injectors if they're clicking
Mar 14, 2010 at 1:13 PM
