1996 Chevy Silverado found that coolant is draining into oi
180,165 MILES • V8 • 4WD • AUTOMATIC
MORE411
what could be wrong and how do i fix it or do i need to get a new engine?
Oct 7, 2010 at 1:48 PM
  • 110,248 POSTS
If the engine was running good, chances are it is fine. It sounds like a bad head gasket which is expensive but not nearly as bad as a new engine. If there is a lot of coolant mixing with the oil, I wouldn't run the engine. It will cause damage to the bearings...
Oct 7, 2010 at 2:51 PM
CHAZZY D
how expensive is a head gasket ? I think a complete gasket set is about $150.oo ? DONT buy the cheap gaskets ... spend the money ONE time and check your heads to see if they are warped, burnt, cracked or rebuildable
Jan 5, 2011 at 7:10 PM
