1996 Chevy Silverado alternator
1996 CHEVROLET SILVERADO
215,000 MILES • V8 • 2WD • AUTOMATIC
KEVADAWG
My voltage meter flucuates and the headlights flicker in time with the meter. I am suspecting the voltage regulator. If that is the culprit can it be replaced or must I change the alternator?
Feb 7, 2009 at 12:12 PM
  • 110,244 POSTS
The regulator is part of the alt. Before replacing it, check for broken or loose wires from the alt. Also, make sure the ground to the engine block is tight and clean.
Feb 7, 2009 at 1:24 PM
