1996 Chevy Silverado
1996 CHEVROLET SILVERADO
156,000 MILES • V8 • 4WD • AUTOMATIC
96 1 TONNER
  • 6 POSTS
My 96 7.4 leaking coolant from front of intake. started truck one morning lifter on drivers side clattered as if it wouldnt pump up, I pulled intake off and found alot of coolant in lifter valley and in one valve cavity could not see any evident area of leakage on intake gaskets such as leak paths will new gaskets solve my problem? Thanks
Dec 1, 2007 at 11:07 PM
PEAR69
  • 1,482 POSTS
Leaking intake gaskets is a common problem with these engines. What concerns me about your leak is that coolant was found in the lifter valley and you heard a lifter rapping. This tells me that there is probably coolant in your oil and it probably circulated through out the oiling system..I would change the oil and change it after only 50 miles again;to be sure most of the coolant is gone out of the oil.
New gaskets will solve this problem if it is indeed the gasket. It can't hurt to do a leak down test to be sure a head is not cracked or a head gasket is not to blame..and if you have the ability, once the intake is back on, pressure test the radiator to see if the block itself is cracked...But coolant in the lifter valley is usually a bad intake gasket or head gasket. Let me know how you make out..
Use the fel-pro intake gasket kit these seem to be the best ---------
Dec 1, 2007 at 11:30 PM
96 1 TONNER
  • 6 POSTS
Thanks Pear69, I pulled head that had coolant in one valve chamber, cant see any crack, head gasket showed no sign of leakage . Can i reuse lifters ?clean them up?
Dec 2, 2007 at 11:13 AM
PEAR69
  • 1,482 POSTS
You can reuse the lifters as long as they do not bind up in the lifter bore and show no sign of wear. Do not forget to prime up the lifters before you set them back in. I hope you are removing both heads. Be sure to check them for any warpage and cracks; especialy around the exaust seats. A long as you've gone this far you mine-as-well go ahead and do a valve job on the heads. Just a little note--the valves in these heads are very durable. You will probably get away with just cleaning them up real good and re-lapping them, but never the less check them closely for pitting - straightness - and wear on the rocker arm end. As long as this motor is stock the fel-pro complete head gasket kit is the best choice for your gasket kit. And make sure you REPLACE THE HEAD BOLTS! Throw the old head bolts away. I think fel-pro has a gasket kit for this motor complete with head bolts, but I'm not sure.
A word of caution though, It is very difficult to just look at a cold head that's off the engine and determine weather or not it is cracked. I would still pressure check the heads or have them magnifluxed by a machine shop, but that's just me..Keep me posted...
Dec 2, 2007 at 11:31 PM
96 1 TONNER
  • 6 POSTS
Thanks again. I had allready started putting it back together . I will pressure test and then pull other head off did get felpro head set but not new bolts , will get those and replace old ones Thanks
Dec 4, 2007 at 6:55 PM
PEAR69
  • 1,482 POSTS
Hey, when you get it back together, do a little burnout for me, ok?
Dec 4, 2007 at 11:32 PM
96 1 TONNER
  • 6 POSTS
Hi pear69 , I got engine back together runs quiet , no lifter noise only problem is sometimes you can hear it sucking to much air thru the breather and when it does this it starts blowing black smoke , It must be some sensor but I dont know which one , Thanks Keith
Dec 5, 2007 at 11:00 PM
PEAR69
  • 1,482 POSTS
If it's a sensor you will most likely get a trouble code. Check your pcv valve. Black smoke is an indicater of oil in the intake or the combustion chamber.
Dec 6, 2007 at 12:47 AM
