1995 Chevy Silverado serpentine belt slipping
172,000 MILES • V8 • 2WD • AUTOMATIC
TBIRDSRUL134
I am having problems with my serpentine belt slipping off the A/C idler pulley on my truck. Originally the Alternator was locking up so I replaced it along with the old A/C idler pulley thinking that would solve the problem. For the most part the belt will stay on but every now and then when I start it up the belt slips off. Could the motor mounts being bad cause this to happen or is there something else I should replace or look at on the truck?
Jan 8, 2008 at 8:56 AM
NO REGRET
  • 5 POSTS
did you check the tensioner put a wrench on move it back and forth it should move smoothly, straight and return to its original position on its own
Feb 24, 2021 at 5:02 AM
TBIRDSRUL134
It did end up being the tensioner pulley. I replaced it yesterday afternoon and all is running smoothly with no slipping. Thank you for the information.
