1995 Chevy Silverado Oil Pressure Problems
114,000 MILES • V8 • 4WD • AUTOMATIC
EVAN5905
Hi, I have a 1995 K1500 Chevy 5.7L 4x4 Pick-up. I have had a problem with my oil pressure lately. I will be driving and the oil pressure will all of a sudden drop to 0 then within 5 to 6 seconds will be back to normal pressure, check oil and it is fine then switched the oil sending unit and it still does this. Any suggestions?
Jan 22, 2010 at 10:23 AM
SCOTTY DEE
  • 592 POSTS
If you have verified sender is good, and oil pressure is adequate, you have a bad cluster.
Jan 27, 2010 at 12:40 AM
