how to bleed the abs brakes
1995 CHEVROLET SILVERADO
DHOOD3170
I was wondering if you could tell me what you have to do to bleed the brakes
Apr 4, 2008 at 12:46 PM
BLACKOP555
  • 10,386 POSTS
You will need to have a scanner tool to open the ABS valve and then follow this guide.
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Feb 22, 2021 at 8:25 AM
DTHOMAS81
i have a 2500 series. i changed the master and all the lines front and rear. also changed proportioning valve. i cant get fluid to the rears at all. any suggestions?
Feb 23, 2021 at 1:27 AM (Merged)
MERLIN2021
  • 17,250 POSTS
BLEEDING BRAKE SYSTEM BLEEDING SEQUENCE BLEEDING SEQUENCE MASTER CYLINDER BLEEDING 1. Place master cylinder in soft-jawed vise. DO NOT overtighten vise. Install bleeder tubes in both outlets of master cylinder. See Fig. 1 . Fill master cylinder reservoir. Ensure ends of bleeder tubes are submerged in brake fluid. 2. Press and release piston assembly until air bubbles are no longer present in fluid flow. Leave bleeder tubes installed on master cylinder. Install master cylinder. 3. Remove bleeder tubes. Connect brake lines at master cylinder. DO NOT fully tighten brake lines at this time. Slowly press brake pedal to floor and hold. Tighten brake lines. Release brake pedal. Bleed brake system. See MANUAL BLEEDING , PRESSURE BLEEDING or VACUUM BLEEDING . Fig. 1: Bench Bleeding Master Cylinder Courtesy of GENERAL MOTORS CORP. MANUAL BLEEDING 1. Fill master cylinder. Install bleeder hose to bleeder screw at first wheel to be serviced. See BLEEDING SEQUENCE under BLEEDING BRAKE SYSTEM . Submerge other end of hose in glass jar partially filled with brake fluid. 2. Open bleeder screw 3/4 - 1 turn. Slowly press brake pedal to floor. Note fluid flow. Close bleeder screw. Release pedal. Repeat procedure until air bubbles are no longer present in fluid flow. NOTE: On vehicles with ABS, wait 15 seconds between pedal strokes when bleeding brake system. On vehicles with Hydro-Boost, check for air bubbles in power steering fluid reservoir. If air bubbles are present, bleed Hydro-Boost system before bleeding brake system. See BLEEDING HYDRO-BOOST SYSTEM in POWER BRAKE BOOSTER - BENDIX HYDRO-BOOST article in this section. Application Sequence "C & K" Series RR, LR, RF, LF NOTE: To prevent air from entering brake system, bench bleed master cylinder before installing. NOTE: Air tends to cling to caliper walls. When bleeding vehicles with disc brakes, lightly tap caliper to help remove air. 1. Retain hold-off valve stem of combination valve using Valve Retainer (J-23709). See Fig. 2 . This allows brake fluid to flow through combination valve and entire system during bleeding.
https://images.2carpros.com/forum/automotive_pictures/62217_valve_1.jpg
CARRILLOF
Brakes problem
1989 Chevy Silverado V8 Two Wheel Drive Manual
We are trying to get all of the air out of the brakes, we tried pumping and loosening individual brakes and after countless bottles of brake fluid nothing seems to work. Any advice or trick to getting the air out and completing this job would be very helpful, thanks
BLUELIGHTNIN6
  • 16,542 POSTS
if you bled them and still has air in them most likely air is coming in from somewhere, faulty master cylinder, bad brake line etc. This guide can help us fix it with instructions below.
https://youtu.be/w7gUsj2us0U
and
SCRRAPPYDO14
I have replaced the master cylider i had pressure for a short period maybe 50 miles they gradually became spungy and now have spungy breaks no pressure. i think i need to bleed the brakes. the fitting are old and rusty. i need to know how to bleed them. i have never done it before.
MERLIN2021
  • 17,250 POSTS
If you can get the bleeders open, fill the master, have a helper pump the pedal a few times and open the bleeder, keep the pedal down while the bleeder is open, close bleeder, repeat until all air is gone, bleed sequence is RR, LR, RF, LF. Dont let the master run out while doing this. Use DOT 3 brake fluid only. Did you bench bleed the master to start?
DAVE HILBERN
Greeteings,
I replaced front pads, rear wheel cylinder, rear brake line and master cylinder. Bled the rear brakes, then the master cylinder then front brakes. But the brake pedal goes to the floor when the truck is on. the brakes work but the pedal is squisshy. Is there a certain order that I need to follow to bleed the brakes?
Thanks
RHALL77
  • 3,361 POSTS
I find this to work good.
1st. Master Cylinder
2nd. Gravity Bleed the whole system Open all bleed screws at the same time for a few minutes until fluid comes out.
3rd. Bleed Rear
A. RR
B. LR
4th. Bleed Front
A. RF
B. LF
