I have a 95 chevy, it spoders badly and it wont stop. I put in a new fuel filter and a tune up and it wont go away.
Monday, August 17th, 2009 AT 10:43 AM
JDL
MECHANIC
Hello, what all did you replace with the tune-up? Use a gage and check fuel pressure. If your still obd1, check for codes. OBD1 should be a 12 cavity datalink connector?
SPONSORED LINKS
Monday, August 17th, 2009 AT 11:06 AM
SLIMTIM89
MEMBER
1 POST
I replace all of it, the wires cap and pluges
Monday, August 17th, 2009 AT 11:14 AM
JDL
MECHANIC
If you have good spark at all the plugs. I'd use a gage and check fuel pressure. Also check codes or have them checked. With TBI fuel system do the injector/s spray pattern look the same? If not maybe a clogged injector. I've seen injector spray patterns that looked good to me, but, the pressure was half of what it should have been.
