1998 Chevy Silverado Start up
WHOOMBA
  • 1998 CHEVROLET SILVERADO
Engine Performance problem
1998 Chevy Silverado V8 Two Wheel Drive Automatic 143k miles
I just recently changed the fuel filter. It was really stopped up. The pressure went from unmeasurable to 45 psi. It has CSFI. Now every time I start it, it stumbles a little and slowly builds up to the proper idle. Any idea what is going on? Thanks
Tuesday, August 25th, 2009 AT 4:58 PM
Your fuel pressure should be 60-66psi being that low 45psi might be causing the problem.
Tuesday, August 25th, 2009 AT 5:17 PM
WHOOMBA
Thats good. I thought I read on hear it should be 04 to 50. I seem to be getting good pressure from the pump. How do I test the fuel pressure regulator on a CSFI system?
Friday, August 28th, 2009 AT 10:44 PM
The fuel regulator is integrated into the CSFI unit its inside the intake manifold/plenum
Saturday, August 29th, 2009 AT 1:19 AM
