1995 Chevy Silverado head lights want come on when starting
RANDY ASHFORD
1995 Chevy Silverado V8 Two Wheel Drive Automatic
We are used to cranking the truck and the head lights would come on automatically. I noticed the lights not responding to the ignition switch. But they will come on when I use the switch in the dash.
What may be causing this problem?
May 31, 2010 at 9:44 AM
BLACKOP555
  • 10,386 POSTS
do you have auto dim lights? auto on lights, or just regular full time daytime running lights?
Jun 1, 2010 at 3:46 AM
RANDY ASHFORD
Jun 1, 2010 at 9:15 PM
BLACKOP555
  • 10,386 POSTS
alright then. first youll want to make sure the fuses are good. after that locate the daytime running light module and check for voltage and ground on the module. then with vechicles key on when the lights shoudl be on check for voltage leaving it for the lights. if your missing voltage out the module is bad. if missing voltage in wiring is at fault. if you have both in and out and no light check the drl sockets. common problem to burn on on the chevs
Jun 2, 2010 at 2:40 AM
