My vehicle has 175K miles on it, but I changed out the engine with a new crate engine at 100K miles. I didn't change out all the sensors, but most of them.
My oil gauge had been fluctuating between 15-40 psi and was very resposive to fluctuations during pedal movement. I figured the Oil Pressure Sending Unit needed changed...so I changed it. Now the engine shows close to 80 psi and stays high until the engine warms up...then it drops to around 50-60 psi.
Any ideas as to what is causing this or is this okay to continue driving?
Feb 7, 2010 at 12:39 PM
