1995 Chevy Silverado door handle
CEBUMWA
Interior problem
1995 Chevy Silverado V8 Four Wheel Drive Automatic
how to replace interior door handle unit
May 13, 2009 at 11:18 AM
DR LOOT
  • 2,311 POSTS
you may be chewing off a little more than you can "handle", you will have to remove the door panel, don't forget the screws where you put your hand to close the door, they are probably covered in dirt you may have to dig them out, then use a spoon that's what it's called it's a special tool to remove the clips without breaking them but you can use a big screwdriver if you break some clips that's okay you can buy them at the auto parts store, once the door panel is removed, you will need to get a drill and drill out the big rivets, to remove the door handle and if you're lucky your local parts store will loan you a riveter to reinstall the door handle, then just reverse the process I just told you.
May 14, 2009 at 7:50 AM
