1995 Chevy Silverado dangerously poor acceleration
SCHWALLDADDY
  • 1995 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 178,000 MILES
The truck starts and idles fine. When I accelerate it starts missing. When I back off the accelaerator it will begin to accelerate again although at a much more gradual rate. Beyond a slight amount of accelerator, it will start to miss. I change the fuel filter on a fairly routine basis and it is equipped with a K&N air filter. The plugs and wires are relatively new. I recently changed the speed sensor (for the second time in the life of the truck) due to malfunction and it had transaxle fluid on it. Is this normal? Could it be related? (It doesn't act the same as a speed sensor malfunction.) Thank you for your advice on this issue.
Friday, February 12th, 2010 AT 7:42 AM
DOCFIXIT
  • 18,828 POSTS
Check engine light on? Fuel pressure 14 psi? Cap and rotor good? Spark blue/white?
Monday, February 15th, 2010 AT 3:02 PM
SCHWALLDADDY
I cleaned the K&N air filter (wasn't that dirty), changed the fuel filter (relatively low miles), sprayed with carb cleaner, and monkeyed with the EGR valve, MAP sensor, TPS. The truck now accelerates fine. Not sure what I did. Any ideas?
Wednesday, February 17th, 2010 AT 10:29 AM
DOCFIXIT
  • 18,828 POSTS
Glad to hear but not sure maybe filter was a little cloged, Maybe you shockedMAP into working?
Wednesday, February 17th, 2010 AT 10:34 AM
