1995 Chevy Silverado Air conditioning compressor cycling on
1995 CHEVROLET SILVERADO
83,000 MILES • V8 • 2WD • AUTOMATIC
JTUBBS
The AC compressor is cycling on/off after the vehicle warms up. It does not do it when its cold. I replaced the heat sensor because it was bad and causing the vehicle to stall due to getting too much gas. This seemed to fix the problem, but it started acting up again, but it is not stalling anymore. I just replaced the pcv, air cleaner and fuel filter.
Oct 27, 2008 at 6:12 AM
DENNYP
  • 1,824 POSTS
wiggle the blower motor control switch and see if the a/c compressor cycles. If so, replace the blower switch.
Oct 28, 2008 at 2:49 AM
