Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Silverado
Climate Control
Air Conditioner
Blows Hot
1995 Chevy Silverado AC
1995 CHEVROLET SILVERADO
119,000 MILES • V8 • 2WD • AUTOMATIC
E1015824
MEMBER
1 POST
My ac in my 1995 silverado truck is blowing hot air all the time.
Jun 22, 2010 at 5:34 AM
MIGHTY_MAX
MEMBER
Get some guages and check the pressure in the system.
While AC is on, low side should be between 40 - 45 psi
High side will be between 200 - 250 psi.
If you just stick guages on w/ AC off, then pressure should be even between both sides.
Maybe 50 - 65 psi both High and low.
Jun 22, 2010 at 5:49 AM
MIGHTY_MAX
MEMBER
Another quick way to tell is if you turn on the A/C and the clutch doesn't kick in.
Usually means no pressure....so an empty or low system.
On my 91 Chevy, it will cause the A/C display on my panel to blink.
Jun 22, 2010 at 5:55 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
