1995 Chevy Silverado
125,000 MILES • V8 • 2WD • MANUAL
JOSEPHWKEOWN
1995 C3500 7.4 v8
The truck starts and runs but the idle will go from 700 to1500 rpms and stall. Some times the service engine soon light comes on but then the idle is at 2000 to 2500 but smooth. I have changed map, tps, iac, egr and ect. The computer was changed by previous owner. There is no back fire runs fine on the road. I did notice when the motor stalls and dies the full pump stays on for 3 to 4 seconds after it dies. If you play the gas petal you can keep it from dying. Thanks for your time.
Nov 2, 2010 at 2:44 PM
  • 110,251 POSTS
Have you checked fuel pump pressure? You could have a bad pump or a bad pressure regulator.
Nov 3, 2010 at 3:29 AM
