Ignition lock replacement
BEEMAN
Suspension problem 6 cyl Two Wheel Drive Automatic 145000 miles
My truck's ignitiion lock locked up on me with the key in and the engine on and I am unable to turn it to the OFF position at all. Had to shut it off by disconnecting the batteries. Anyway, I have a replacement cylinder, I have pulled the steering wheel off, taken off the first ring (iff you will) that is held in place by two small screws with a torx head. Now I am stuck. I can not seem to figure out how to proceed from here. Hand an all help would be GREATLY appreciated. Thank you.
BTW - I doubt this matters but this is a 6.5 turbo diesel.
Aug 4, 2009 at 4:14 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
First off, is this vehicle equipped with tilt or standard steering column? Also, is it floor or column shift?
Aug 4, 2009 at 4:20 AM
BEEMAN
[quote:92f5b7fd60="bluelightnin6"]Hello and thanks for the donation!
First off, is this vehicle equipped with tilt or standard steering column? Also, is it floor or column shift?[/quote:92f5b7fd60]
It has tilt steering with the column shift.. Thanks
Aug 4, 2009 at 5:10 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Sorry for the delay. Here is the information needed to replace your vehicle's ignition lock cylinder. Do not have to remove steering column from vehicle
https://images.2carpros.com/forum/automotive_pictures/261618_Noname_781.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname2_205.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname3_72.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname4_41.jpg
https://images.2carpros.com/forum/automotive_pictures/261618_Noname5_19.jpg
Aug 6, 2009 at 1:50 PM
  • 55,841 POSTS
Here are diagrams to help you see how to do the job
Check out the diagrams (Below)
Cheers, Ken
Jan 25, 2018 at 2:50 AM
