1994 Chevy Silverado how to bypass AC
1994 CHEVROLET SILVERADO
HPRESSLER
I would like to bypass my air-conditioner pully, it does not work and I do not use it now or plan to. I'm sure I will need a different belt, would like to know witch one I will need as well as the routing of it
Oct 9, 2010 at 9:50 AM
  • 110,236 POSTS
If I recall, you have two ways to do this. First, you can check if there is a bypass pulley for compressor. They make them for many vehicles and then you can use the same belt and diagram. If one is not available, you should be able to use the belt designed for the vehicle without AC. If you look at the belt routing diagrams site listed on this page, it will show you both ways, with and without AC.
Check it out and let me know what you find.
Feb 24, 2021 at 5:02 AM
