1994 Chevy Silverado How do I remove torque conv bolts
SAMDU
Transmission problem
1994 Chevy Silverado Four Wheel Drive Automatic 310000 miles
how do I remove the torque converter bolts on my CK1500 engine that is locked up. Trying to get engine out of truck.
Feb 6, 2010 at 9:37 AM
  • 75,988 POSTS
Go thru the inspection plate,you to go behind the flexplate to get at the bolts by turning the crankshaft at the same time
Feb 6, 2010 at 11:09 AM
DENNYP
  • 1,824 POSTS
If the engine is locked up and won't rotate, you should be able to pull the engine with the torque converter attached. If you don't have enough room to do that, you will need to pull the transmission before the engine.
Feb 6, 2010 at 11:52 AM
  • 75,988 POSTS
1994 Chevy Silverado How do I remove torque conv bolts Missed this one: ( Locked up )-go Denny's way that's the only way out, perfect suggestion -Later Denny
Feb 6, 2010 at 12:03 PM
SAMDU
Thanks for the info!
Feb 6, 2010 at 1:15 PM
  • 75,988 POSTS
Or you can pull both the engine and tranny together at one time-your wish-just take extra careful with a good hoist/sling you'll make it- BTDT
Feb 6, 2010 at 1:40 PM
