My 1994 Ext cab 4x4 Silverado 1/2 ton will not switch from hi beams to low. It is stuck on hi. The switch clicks and the rod moves the pieces up and down with the motion of the handle. Everything seems to be plugged in correctly. When I hit the switch the hi beams flash but it still stays on hi. Any suggestions would be greatly appreciated.
Feb 28, 2010 at 10:40 AM
