1994 Chevy Silverado Headlight switch/dimmer not changing h
1994 CHEVROLET SILVERADO
152,000 MILES • V8 • 4WD • AUTOMATIC
GEEBI18
  • 25 POSTS
My 1994 Ext cab 4x4 Silverado 1/2 ton will not switch from hi beams to low. It is stuck on hi. The switch clicks and the rod moves the pieces up and down with the motion of the handle. Everything seems to be plugged in correctly. When I hit the switch the hi beams flash but it still stays on hi. Any suggestions would be greatly appreciated.
Feb 28, 2010 at 10:40 AM
BLUELIGHTNIN6
  • 16,542 POSTS
first check fuse # 8 (20 amp).
does it have daytime running lights? if so, do the DRLs work properly on low beam?
Feb 28, 2010 at 11:22 AM
GEEBI18
  • 25 POSTS
As far as I know it does not have the daytime running lights. If it does then they do not work. I will check that fuse right now.
Feb 28, 2010 at 11:24 AM
BLUELIGHTNIN6
  • 16,542 POSTS
ok, only other thing associated with your vehicle's low beams then is the switch, wiring and bulbs. if wiring and bulbs are good then suspect faulty dimmer switch.
Feb 28, 2010 at 11:25 AM
GEEBI18
  • 25 POSTS
Checked all the fuses. Must be a faulty switch. Thanks for your help. I really do appreciate it.
Feb 28, 2010 at 11:56 AM
GEEBI18
  • 25 POSTS
I put a new dimmer switch on yesterday. Boy was that top screw a mother to get out. Thanks to the replies it helped a lot.
Mar 2, 2010 at 11:09 AM
GEEBI18
  • 25 POSTS
I also left you + feedback. Thanks!
Mar 2, 2010 at 11:25 AM
