Just bought this truck from a private owner. The brake pedal went all the way to the floor and seemed to barely stop. I came home and installed a new master cylinder. I bleed a the brakes. Pedal seemed harder but when I started it up it wasnt. And after time it seems to slowly be getting worse and getting like it was before I changed it.
A few things, when I was bleeding the system one caliper in the front either had alot of air or something else casue I had the bleeder screw open and no fluid then after a few moments out came fluid. Same thing happen in back brakes.
There are some electronic looking board persay connected to master cyclinder.
Oct 27, 2010 at 6:57 PM
