1994 Chevy Silverado Brake light switch
34GHOSTRIDER
Brakes problem
1994 Chevy Silverado V8 Two Wheel Drive Automatic
The brake lights have stoped working. I have changed the brake light switch, but they still don't work. All of the other lights work...blinkers, tail lights. I read on one of the other questions about adjusting the switch...how do you do that? Can that be the problem? The brake light fuse looks fine.
Feb 2, 2009 at 2:22 PM
  • 75,988 POSTS
The brake pedal arm should be depressing the brake switch plunger, when pedal is depressed the plunger should extent. If the pedal is not fully extended the light will not come on.
Feb 2, 2009 at 8:39 PM
34GHOSTRIDER
It turns out it was a fuse, but not the brake light fuse. This fuse also operated the door "dinger" and some of the cab lights.
Feb 4, 2009 at 1:59 PM
