1993 Chevy Silverado TPS code 22
220,000 MILES • V8 • 2WD • AUTOMATIC
JSINDIONG
The engine of my 93' Chevy pick-up idles high. It also shifts hard. It started a month ago a couple of times, then ran fine for a while. It has started back up again. I get a code of 22. I've replaced the TPS and Idle Air Control valve. Didn't help. Any ideas?
Jul 4, 2009 at 8:05 AM
KHLOW2008
  • 41,812 POSTS
Hi jsindiong, Thank you for the donation. Here are the schematics and flowchart for analysis. Go through them and see if it helps.
https://images.2carpros.com/forum/automotive_pictures/192750_Code22TPSC500Fig12_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_Code22TPSC500a01a_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_Code22TPSC500a01b_1.jpg
https://images.2carpros.com/forum/automotive_pictures/192750_Code22TPSC500a01c_1.jpg
Jul 4, 2009 at 11:07 PM
JSINDIONG
I actually fixed the problem this morning. I had been removing the fuse to the ECM and turning the key to run, thinking it erase its memory. Tried disconnecting the battery for a few minutes. Started it up and it runs just fine now! Yea!
Jul 5, 2009 at 11:05 AM
