1993 Chevy Silverado starting
OMAR 986
  • 1993 CHEVROLET SILVERADO
  • V8
  • 4WD
  • 127,000 MILES
After engine gets hot it wont turn over. Lights are bright all instruments come on even a jump wont help
Tuesday, October 27th, 2009 AT 7:47 PM
It wont even turn over now.
Did you meant it cranks over and will not start or just won't crank at all/nothing/nada?
Cranks and w/n start
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
No crank at all/nothing/nada:
Could be the starter, starter relay, park and neutral switch and ignition switch assuming the battery and connections are good.
Tuesday, October 27th, 2009 AT 8:05 PM
OMAR 986
After running for 1/2 hr or more I shut the engine off turn key on and there is no crank or click lights are bright gauges light up not even a jump will start it.I let it sit for awhile until it cools down then it will start.
Tuesday, October 27th, 2009 AT 11:02 PM
QUAGMIRE86
  • 98 POSTS
Sounds like a crankshaft position sensor to me. (The accumulated heat from your engine is affecting the sensor signal). At least, that is the first thing I would check.
Tuesday, October 27th, 2009 AT 11:57 PM
STUMPFY09
  • 6 POSTS
The ignition control module located under the distributor cap can foul up after heating up and not let it start also.
Friday, October 30th, 2009 AT 3:27 PM
