Joe is correct...there is a coolant sensor next to the t-stat housing but the main temperature monitor of the coolant is the temperature switch. You can find it under hood, on the driver side, just below the valve cover, between the front and center exhaust ports, mounted in the cylinder head. If the wires to the switch are broken or disconnected, your dash heat gauge will not work
Jan 25, 2009 at 1:20 PM
