1993 Chevy Silverado dies
LIMPINGCHEVY
  • 1993 CHEVROLET SILVERADO
Engine Mechanical problem
1993 Chevy Silverado V8 Two Wheel Drive Automatic 150xxx miles
truck dies and won't start. Has to set for 20 to 30 min, then runs about a block and dies again. I have replaced the fuel pump and filter, rotor, cap and wires and oxygen sensor.
Wednesday, June 3rd, 2009 AT 7:03 PM
Do below and let me know asap
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, cap and rotor /distributor pick-up coil, ignition control module, ECM, Ignitor cam and crank sensors- Note: If it doesn't apply disregard it
Wednesday, June 3rd, 2009 AT 7:11 PM
