1993 Chevy Silverado coolant leak
279,000 MILES • V8 • 4WD • AUTOMATIC
DJWINSLADE
My question is my truck started to leak anti freeze out the bottom by my radiator.i cant tell were the leak is coming from?The truck will heat a little but when i but my hand on the top hose its cold?Plus i can touch the top of the radiator cap,and it is also cold when the truck is running and warm?do you have any idea whats wrong?
Jan 28, 2009 at 5:25 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:2fc656c428="djwinslade"]Engine Cooling problem
1993 Chevy Silverado V8 Four Wheel Drive Automatic 279000 miles
My question is my truck started to leak anti freeze out the bottom by my radiator.i cant tell were the leak is coming from?The truck will heat a little but when i but my hand on the top hose its cold?Plus i can touch the top of the radiator cap,and it is also cold when the truck is running and warm?do you have any idea whats wrong?[/quote:2fc656c428]
The leak can be coming from anywhere on the radiator to include the lower hose at the connection. If it the original radiator I would say it is time to change it.
The top hose and the radiator cap being cool or colcan indicate a stuck closed thermostat. Looking at the temp gauge before your problem were did the needle run and now were does it run. Also what is the outside temp were you live. this could be why it does not overheat.
Jan 28, 2009 at 5:37 AM
