1993 Chevy Silverado 1993 Chevy Silverado
120,000 MILES • V8 • 4WD • AUTOMATIC
KWALLACE2122
I have a 93 silverado that runs but dies. I was told that it was my distributor but it wasn't by a mechanic. I thought it might be my alternator but before I bought anything I thought I would ask you.
Apr 5, 2009 at 4:07 AM
JDL
  • 16,098 POSTS
Hello, Are there any codes? Your obd1, you should be able to check codes yourself, see if anything shows up.
How long since a tune-up? Can you check fuel pressure?
Apr 5, 2009 at 4:20 AM
KWALLACE2122
How do you check the fuel pressure? also whats a obd1 code?
Apr 5, 2009 at 4:58 AM
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_aldl_12.jpg
There should be a datalink connector under your dash, you use a jumper between the A & B terminals, turn the key on, no crank, the (check engine lite) goes to flashing, you count the flashes to get the codes. OBD stands for ( On Board Diagnostics). With tBI fuel injection, you can see the fuel injectors spray gas, with the engine cranking. To check fuel pressure, you tee a gage into the supply line.
Apr 6, 2009 at 1:25 AM
