1992 Chevy Silverado pinion shaft
1992 CHEVROLET SILVERADO
100,000 MILES • V8 • 2WD • AUTOMATIC
DISTEL55
the little bolt that holds the shaft in place broke,any ideas on getting the rest of the bolt out thank u
Sep 18, 2009 at 1:39 PM
QUAGMIRE86
  • 98 POSTS
I'm not quite sure which bolt you are refering to. The pinion shaft, on the rear differential, is a big bolt so I am thinking that the nomenclature of the part is throwing me off. Could you describe in greater detail which part you are having a problem with?
Sep 18, 2009 at 3:59 PM
