1992 Chevy Silverado no brake pedal when applying brakes
174,000 MILES • V8 • 2WD • AUTOMATIC
STEEEL38
There is no pedal when stopping vehical pedal goes almost to floor before brakes start working. We just bleed the lines and there is no air. What else could it be?
Apr 18, 2009 at 9:40 AM
  • 75,988 POSTS
If there's no leak anywhere sounds like the master cylinder has an internal leak
Apr 18, 2009 at 10:09 AM
STEEEL38
Eventhough we replaced the master cylinder?
Apr 18, 2009 at 10:43 AM
  • 75,988 POSTS
Do you have a leakage anywhere -such as the calipers/wheel cylinders/lines-If it has and ABS unit check that too.
Apr 18, 2009 at 10:50 AM
STEEEL38
no leaks anywhere, I think it has ABS in back only, it is a 1992 chevy silverado c1500.
Apr 18, 2009 at 10:59 AM
  • 75,988 POSTS
Did you bench bleed the M/C before you bleed the wheels. Bleeding procedures-the M/C, ABS unit then the wheels.
Apr 18, 2009 at 11:39 AM
