Hi thumbslikearacoon and welcome to 2carpros
When key at run position -do you hear the fuel pump come on for 2secs?-If not the fuel pump could be shot/in tank pick-up screen clogged by debris to include the fuel filter-If so check the fuel pressure if its within specification-incorrect pressures will caused it not to start. The fuel pump is located in the fuel tank-You have to drop the fuel tank to get at it-
SPONSORED LINKS
Wednesday, October 22nd, 2008 AT 3:52 PM
