HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Chevrolet
Silverado
Fuel System
Fuel Pump
SPONSORED LINKS
1988 Chevy Silverado Fuel Pump
MARK MESSER
MEMBER
1988 CHEVROLET SILVERADO
V8
4WD
AUTOMATIC
16,700 MILES
Truck won't start, no power to fuel pump. No power to injectors
Saturday, June 7th, 2008 AT 8:33 PM
BMRFIXIT
MECHANIC
Check fuses and relays
check fusible links
check ignition switch and wiring
SPONSORED LINKS
Saturday, June 7th, 2008 AT 9:28 PM
BLACKOP555
MECHANIC
Check your fuses and relays first of all.
Do you get power to the pump when the key is first turned to the on position?
You getting spark also?
Could be faulty pickup coil not showing a voltage and thus causing a no spark/pulse problem.
Saturday, June 7th, 2008 AT 9:38 PM
Please
login
or
register
to post a reply.
Related Fuel System Fuel Pump Content
1990 Chevrolet Silverado Fuel Pump
Can't Get The Electrical Plug Off The Fuel Pump Sender Assembly. Is There Some Trick To It?
Asked by
BURNINGWELL
1990
CHEVROLET SILVERADO
VIDEO
How to Replace Fuel Pump
Instructional repair video
GUIDE
Fuel Pump
Fuel Pump Features
Fuel Pump
How Does The "high Temp Fuel Sensor" Work On My '94 Chevy Truck Fuel Pump?
Asked by
andygears
1994
CHEVROLET SILVERADO
Poss Fuel Pump?
I Have A 2000 Chevy Silverado 1500 5.3l. I Am Getting A P0300 (random Cylinder Misfire) And P0131 (o2 Sensor Bank 1 Sensor 1) Code. My...
Asked by
mcabee.duck
2000
CHEVROLET SILVERADO
1997 Chevy Silverado Fuel Pump
Engine Mechanical Problem 1997 Chevy Silverado V8 Four Wheel Drive Automatic The Fuel Pump Sometimes Will Run If The Key Is Off Or On...
Asked by
jussmedley
1997
CHEVROLET SILVERADO
Fuel Pump Issues With Silverado
I Put A New Fuel Pump In A 1999 Silverado 5.3 Ltr 4x4, Before Doing This I Was Able To Turn The Key To The Aux Position And Wait For The...
Asked by
chevyrod
1 ANSWER
CHEVROLET SILVERADO
VIEW MORE
SPONSORED LINKS
Fuel Pump Replacement BMW
Fuel Pump Replacement Chevrolet Silverado
Online car repair manuals
